Problems with Soyo Dragon+ Raid Setup
mjquilly
1,692
I'm having troubles setting up an array on my Dragon+ Board. All I have installed on the board, other than CPU and memory, is my Radeon AIW, HDD's set to Master on IDE 3 and 4, and my DVD and CDRW on IDE2. After POSTing, and getting through the BIOS screens, the RAID setup utility starts and shows "Scanning IDE Drives......." This shows for awhile, then I get this message:
<< "Warning: FastTrak does not detect proper interrupts, Please check your PCI IRQ setup, and make sure the PCI slot support Bus Master Operations" >>
What do I need to change?
sygyzy
14,001
4
Is the jumper on the M/B set to RAID? Is RAID enabled in your Bios? What is the boot sequence?
