It is the Ultra100 TX2. I have just a sinlge HD ( new maxtor 60gb) connected to the card. The hd mode is cable select.
Anyway, I do a fresh installation of XP onto my old 40gb Maxtor ( is on the on-boad IDE ). Everything works fine. I did not install the drivers for the controller card during XP installtion as I didn't need the 60gb hd at the time. Anyway, boot into windows, and XP installs the drivers and i see the unformatted HD in My computer. I reboot back in dos and do fdisk. Go to create a partition on the drive and it only has NTFS. SO I go back to Windows and use Partition Magic 7.0.. to format and create a FAT32 partition. I restart and it doesn't see the HD. But than I shut down and boot up windows and it sees it perfect. K I have 60 gb free space now. I also flashed the controller card bios to the newest one...
I start moving Music and My Documents over, around 4-5 gb. Everything is moved fine. I go to bed and woke up this morning and there are errors saying, can't write to drive.. blah errrors. I had to restart and now when I boot up in Windows, My Computer sees the drive as a Unformatted dive and so does Partition Magic .. WTF
In the event viewer, the driver for the card had a system time out failure.... The card is on IRQ 10 and it is by itself. During installtion of XP, I chose standard PC.
I did have the drivers installed off the provided floppy, i removed those and now running the drivers that XP has.
OK now, I re-format and create a fat32 partition ( using Partition Manager). Restart and the HD is not seen. I use a program called "bootitng" from download.com. It formats and creates a Fat-32 partition. I go to windows and the HD is seen fine. I shut down and restart back into windows. The HD is not seen. Not in partition magic or in my computer. I have also used FDISK to create a Primary Fat-32 partition on the drive. I go into windows and it doesn't see the HD either.
arrghh
What is going on ? Pls HELP
BTW, during bootup...the HD is picked up but is not being seen in Windows XP Pro.
Thanks
arrghh
Thanks
