GeezerMan
We are having some problems with the overclocked 3800+ X2, socket 939. Twice now in 3 days, it completely shut down. Just about at idle both times. Just turned itself off. Cool and quiet is not enabled. Temps are fine. Could some voltages need to be raised? I?m thinking ram voltages, chipset voltage, maybe power supply. How about the surge protector?
Thanks
Here's the specs from an earlier post:
The goal was to get to 2.6GHz on as low as possible voltage, and have decent temps. I think we suceeded pretty well. We have it at 2.6GHz, dual Orthos stable for 24 hours nonstop. Under 100% Orthos load, temps were at 55 degrees Celsius in a 78 degree F room. Ram is at 2.5-3-3-6, all other settings at default.
I guess I just have some simple questions. It's OK to have the HT at 1043 if it's stable, right? Should we bother to adjust any other ram settings?
Biostar Tforce6100
Ultra X-finity 500 watt
7600GT video
200GB SATA
2GB Corsair XMS PC3200
X2 3800+ 939
AMD Heatpipe HSF
Arctic Silver 5
DVD burner
CPU-Z indicates:
stock CPU voltage
CPU multiplier is at 10
2.608 GHz
HT Link 1043
Ram at 217.4 MHz, 2.5-3-3-6 1T
Thanks
Biostar Tforce6100
7600GT video
200GB SATA
X2 3800+ 939
AMD Heatpipe HSF
Arctic Silver 5
DVD burner
CPU-Z indicates:
stock CPU voltage
2.608 GHz
HT Link 1043
