Problems with Open GL "Games and 3DS MAX 4" and a GF2 GTS 32MB.
TheLizardMan
First here are my system specs
MSI K7T Turbo
1.2ghz 266 T-Bird @ 1.2
256mb sdram pc-150 @ 133
Creative Labs Geforce2 GTS 32mb Latest Drivers
Turtle Beach Santa Cruiz
Maxtor ATA-100 Controller
3-Com 10/100 Nic PCI
TDK 12-10-32
Windows 2000 SP2 + All Updates
Okay, In games my computer with out any warning will just reboot. This has been going on for a while now and I'm not sure why. I have tried just about every driver for my video card and that has not helped. I first thought it was my motherboard because I have other problems that look like it might be the motherboard. But I just installed 3D Studio Max 4 and I am having the same problems. I also updated max to 4.2 and it doesn't help.
If anyone has ever had this problem before and could offer some help then please do. BTW I once got some artic silver epoxy on my video card and it would not boot. So I spent many hours with a rag, q tips and rubbing alcohol. And I did manage to clean it off. Could some of the epoxy still be on the card and to be causing it to malfunction some times? It just seems weird that it would screw up every now and then "mainly in Opengl" and no other time.
-Tnx
Via 4 in 1 drivers ? directx version ? and also power supply can occasionly cause problems such as your having.
Latest 4in1 and i have direct x 8.1. My power supply is a enermax 330 watt and it is doing fine.
would you say the problem is more towards the video card or mobo?
A buddy of mine said this...
"There is a very good possibility that you could have zapped your vid card whilst you were cleaning of the epoxy. Devices like that are called walking wounded because they seem fine and pass all the tests but when they are put into real service then they don't perform right. I used to do Electrostatic Discharge (ESD) testing a few years ago on the new chips TRW was making."
