Problems with nvidia and Mandrake 9.0
After researching a little bit i downloaded all the drivers and rpmed them in to my setup.I downloaded the latest kernel from http://nekropolis.assetdisk.com and i
have installed the kernel. Now i get flashes of red and green in my screen.
I also see the green NVIDIA symbol for a second or so and then everything
becomes black and all i have is X (mouse pointer) in the screen. I have
attached the XFree86.0.log with this post. Please tell me what is going on
here.
XFree86 Version 4.2.1 / X Window System
(protocol Version 11, revision 0, vendor release 6600)
Release Date: 3 September 2002
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/)
Build Operating System: Linux 2.4.18-23mdkenterprise i686 [ELF]
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Mon Nov 18 17:04:53 2002
(==) Using config file: "/etc/X11/XF86Config-4"
(==) ServerLayout "PCI"
(**) |-->Screen "Screen PCI" (0)
(**) | |-->Monitor "MyMonitor"
(**) | |-->Device "NV PCI"
(**) |-->Input Device "Keyboard1"
(**) Option "AutoRepeat" "250 30"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc105"
(**) XKB: model: "pc105"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(WW) Option "XkbOptions" requires an string value
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Mouse1"
(**) FontPath set to "unix/:-1"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(**) Option "AllowMouseOpenFail"
Using vt 7
(--) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.5
XFree86 XInput driver : 0.3
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.3
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.2.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.3
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.2.1, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.5
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x80008864, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3099 card 1106,0000 rev 00 class 06,00,00 hdr
00
(II) PCI: 00:01:0: chip 1106,b099 card 0000,0000 rev 00 class 06,04,00 hdr
01
(II) PCI: 00:08:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr
00
(II) PCI: 00:11:0: chip 1106,3147 card 1106,0000 rev 00 class 06,01,00 hdr
80
(II) PCI: 00:11:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr
00
(II) PCI: 00:11:2: chip 1106,3038 card 0925,1234 rev 23 class 0c,03,00 hdr
00
(II) PCI: 00:11:3: chip 1106,3038 card 0925,1234 rev 23 class 0c,03,00 hdr
00
(II) PCI: 00:11:5: chip 1106,3059 card 1462,4710 rev 40 class 04,01,00 hdr
00
(II) PCI: 01:00:0: chip 10de,0201 card 1462,5106 rev a3 class 03,00,00 hdr
00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0c (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
[0] -1 0xdde00000 - 0xdfefffff (0x2100000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0xd5b00000 - 0xddcfffff (0x8200000) MX
(II) Bus -1: bridge is at (0:17:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) NVidia GeForce3 Ti 200 rev 163, Mem @ 0xde000000/24,
0xd8000000/26, 0xddc80000/19, BIOS @ 0xdfef0000/16
(II) Addressable bus resource ranges are
[1] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0x00000000 - 0x000000ff (0x100) IX
(II) Active PCI resource ranges:
[0] -1 0xdfffff00 - 0xdfffffff (0x100) MX
[1] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX
[2] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[3] -1 0xddc80000 - 0xddcfffff (0x80000) MX(B)
[4] -1 0xd8000000 - 0xdbffffff (0x4000000) MX(B)
[5] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[6] -1 0x0000e800 - 0x0000e8ff (0x100) IX
[7] -1 0x0000e400 - 0x0000e41f (0x20) IX
[8] -1 0x0000e000 - 0x0000e01f (0x20) IX
[9] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[10] -1 0x0000ec00 - 0x0000ecff (0x100) IX
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0xdfffff00 - 0xdfffffff (0x100) MX
[6] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX
[7] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[8] -1 0xddc80000 - 0xddcfffff (0x80000) MX(B)
[9] -1 0xd8000000 - 0xdbffffff (0x4000000) MX(B)
[10] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[11] -1 0x0000ffff - 0x0000ffff (0x1) IX
[12] -1 0x00000000 - 0x000000ff (0x100) IX
[13] -1 0x0000e800 - 0x0000e8ff (0x100) IX
[14] -1 0x0000e400 - 0x0000e41f (0x20) IX
[15] -1 0x0000e000 - 0x0000e01f (0x20) IX
[16] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[17] -1 0x0000ec00 - 0x0000ecff (0x100) IX
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "v4l"
(II) Loading /usr/X11R6/lib/modules/drivers/linux/v4l_drv.o
(II) Module v4l: vendor="The XFree86 Project"
compiled for 4.2.1, module version = 0.0.1
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
compiled for 4.2.1, module version = 1.0.1
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.3123
(II) Loading extension GLX
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) v4l driver for Video4Linux
(II) NVIDIA XFree86 Driver 1.0-3123 Tue Aug 27 16:00:08 PDT 2002
(II) NVIDIA: NVIDIA driver for: RIVA TNT, RIVA TNT2, Vanta,
RIVA TNT2 Ultra, RIVA TNT2 Model 64, Aladdin TNT2, GeForce 256,
GeForce DDR, Quadro, GeForce2 MX/MX 400, GeForce2 MX 100/200,
Quadro2 MXR/EX/Go, GeForce2 Integrated GPU, GeForce2 GTS,
GeForce2 Ti, GeForce2 Ultra, Quadro2 Pro, GeForce4 MX 460,
GeForce4 MX 440, GeForce4 MX 420, Quadro4 500/550 XGL,
Quadro4 200/400 NVS, NV18, NV18 , NV18 , NV18, NV18GL, NV18GL ,
NV18GL , 0x01F0, GeForce3, GeForce3 Ti 200, GeForce3 Ti 500,
Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400, GeForce4 Ti 4200,
Quadro4 900 XGL, Quadro4 750 XGL, Quadro4 700 XGL, NV28, NV28 ,
NV28GL, NV28GL , GeForce2 Go, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, GeForce4 440 Go 64M,
GeForce4 410 Go 16M, Quadro4 500 GoGL
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce3 Ti 200 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[11] 0 0x000a0000 - 0x000affff (0x10000) MS
[12] 0 0x000b0000 - 0x000b7fff (0x8000) MS
[13] 0 0x000b8000 - 0x000bffff (0x8000) MS
[14] -1 0x0000ffff - 0x0000ffff (0x1) IX
[15] -1 0x00000000 - 0x000000ff (0x100) IX
[16] -1 0x0000e800 - 0x0000e8ff (0x100) IX
[17] -1 0x0000e400 - 0x0000e41f (0x20) IX
[18] -1 0x0000e000 - 0x0000e01f (0x20) IX
[19] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[20] -1 0x0000ec00 - 0x0000ecff (0x100) IX
[21] 0 0x000003b0 - 0x000003bb (0xc) IS
[22] 0 0x000003c0 - 0x000003df (0x20) IS
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NVIDIA(0): Linear framebuffer at 0xD8000000
(--) NVIDIA(0): MMIO registers at 0xDE000000
(--) NVIDIA(0): VideoRAM: 65536 kBytes
(--) NVIDIA(0): Detected TV Encoder: Brooktree 868
(--) NVIDIA(0): Display 0: maximum pixel clock at 8 bpp: 350 MHz
(--) NVIDIA(0): Display 0: maximum pixel clock at 16 bpp: 350 MHz
(--) NVIDIA(0): Display 0: maximum pixel clock at 32 bpp: 350 MHz
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) NVIDIA(0): MyMonitor: Using hsync range of 31.00-80.00 kHz
(II) NVIDIA(0): MyMonitor: Using vrefresh range of 56.00-76.00 Hz
(II) NVIDIA(0): Clock range: 12.00 to 350.00 MHz
(II) NVIDIA(0): Not using default mode "640x350" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x175" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "720x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "360x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x480" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x240" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "800x600" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "400x300" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1024x768" (bad mode
clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "512x384" (bad mode
(II) NVIDIA(0): Not using default mode "1024x768" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "512x384" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1280x960" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x480" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x512" (hsync out of range)
(WW) (1600x1200,MyMonitor) mode clock 162MHz exceeds DDC maximum 140MHz
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1920x1440" (hsync out of range)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1400x1050" (hsync out of range)
(II) NVIDIA(0): Not using default mode "700x525" (hsync out of range)
(**) NVIDIA(0): Validated modes for Display Device 0:
(**) NVIDIA(0): Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NVIDIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
(--) NVIDIA(0): Display dimensions: (340, 270) mm
(--) NVIDIA(0): DPI set to (76, 72)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.1
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0xddc80000 - 0xddcfffff (0x80000) MX
[1] 0 0xd8000000 - 0xdbffffff (0x4000000) MX
[2] 0 0xde000000 - 0xdeffffff (0x1000000) MX
[3] -1 0xffe00000 - 0xffffffff (0x200000) MX(B)
[4] -1 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[5] -1 0x000f0000 - 0x000fffff (0x10000) MX
[6] -1 0x000c0000 - 0x000effff (0x30000) MX
[7] -1 0x00000000 - 0x0009ffff (0xa0000) MX
[8] -1 0xdfffff00 - 0xdfffffff (0x100) MX
[9] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX
[10] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[11] -1 0xddc80000 - 0xddcfffff (0x80000) MX(B)
[12] -1 0xd8000000 - 0xdbffffff (0x4000000) MX(B)
[13] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[14] 0 0x000a0000 - 0x000affff (0x10000) MS(OprD)
[15] 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprD)
[16] 0 0x000b8000 - 0x000bffff (0x8000) MS(OprD)
[17] -1 0x0000ffff - 0x0000ffff (0x1) IX
[18] -1 0x00000000 - 0x000000ff (0x100) IX
[19] -1 0x0000e800 - 0x0000e8ff (0x100) IX
[20] -1 0x0000e400 - 0x0000e41f (0x20) IX
[21] -1 0x0000e000 - 0x0000e01f (0x20) IX
[22] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[23] -1 0x0000ec00 - 0x0000ecff (0x100) IX
[24] 0 0x000003b0 - 0x000003bb (0xc) IS(OprU)
[25] 0 0x000003c0 - 0x000003df (0x20) IS(OprU)
(II) NVIDIA(0): AGP 4X successfully initialized
(II) NVIDIA(0): Setting mode "1024x768"
(II) NVIDIA(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid filled trapezoids
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Driver provided FillSolidRects replacement
Driver provided FillSolidSpans replacement
Driver provided WritePixmap replacement
Driver provided ReadPixmap replacement
Setting up tile and stipple cache:
16 128x128 slots
4 256x256 slots
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-GLX
(II) Loading extension NV-CONTROL
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) [GLX]: Calling GlxExtensionInit
(II) Keyboard "Keyboard1" handled by legacy driver
(**) Option "Protocol" "PS/2"
(**) Mouse1: Protocol: "PS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/psaux"
(**) Option "Emulate3Buttons"
(**) Option "Emulate3Timeout" "50"
(**) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
(==) Mouse1: Buttons: 3
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
Did you edit out the nv driver in the config file? Thanks for including the log! We dont see such kindness all that often 😉
He's using the nvidia drivers (sheesh, didn't you read the log n0c ;0) There is nothing wrong I can see, perhaps something in the XF86Config-4 config file?
I skimmed through it, but there was something in there that made me think the other might still be in the config file and trying to load or something...
