Problems with Nortons utilities 2001 Pleasa help.
Renob
7,596
When I try to load nortons utilities 2001 it starts to load and at 3% loaded i get a message that says: An error occurred durring the move data process:-117 any one has a clue what that means and how to get around it...Thanks for any info.....
Mem
21,476
13
Make sure everything in the background is disabled like anti-virus(software wise) & try again,if you still get problems I recommend you take it back to the store & buy Ontrack Systemsuite 3 or Fix-it Utilities 3, this package is excellent,IMHO it`s better then Nortons utilities 2001.
Renob
7,596
Thanks mem for the responce to my problem. what I dont get is I had it work ing on my system for a month and the only thing that changed is now I put in a new mobo but i dont think that should cause the problem..
Mem
21,476
13
You could try going to Norton website see if they can help or send them a email, here is theirtech page
