I apologise if this is not the correct forum.
I am getting a high pitched whine from my crt when my system changes graphics res. I changed from a Gforce3 to a radeon 8500 and even tried an old Kyro that I had. I have tried 3 different crts and they all do it.
Suggestions, ideas, go away?
Thank you
The problem was found....
By accident, I needed to move some equipment and I moved the plug for the crt to a different spot on the ups. The sound disappeared. I checked and played with it and found that there were 2 receptacles on the ups that produced the problem. I have replaced the ups and the problem went away.
Thank you for the responses
Thank you
