- Jun 8, 2005
- 16
- 0
- 0
Hi all. Great forum you have here. I am having a small problem with my newly built system. The specs include:
DFI: NF4 SLI-DR motherboard
AMD 4000+ Processor ( ZALMAN CNPS7000B-CU 92mm 2 Ball Cooling Fan )
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum System Memory
2x Maxtor 300 GIG SATA 16mb cache hard drives
BFG 6800 GT PCIx
SoundBlaster Audigy 2 oem
Pioneer A09 DVD BURNER
OCZ 520 watt powersupply
NOTE: I have yet to update bios. so i'm currently using the bios that it came with straight out of the box ( i don't know the revision number because i am at work at the moment)
The first problem i noticed that when trying to install windows Xp it was extremely slow booting off of the cd.. loading the files neccessary for setup.. (i tried a different cd-rom) Once i finally get into setup. i do a Quick format FOR NTFS.. and right after it starts to load files neccessary for the XP setup it crashes into a blue screen..
Any help is greatly appreciated.
BFG 6800 GT PCIx
