Hello,
I recently built a new system, and everything was going fine, I booted from a usb iso out of the bios, I was going through the windows 10 setup, did the custom (not upgrade) install, selected my primary drive, which is a 500gb SSD with about 200gb of data on it from an old build, but then I ran into trouble. I wasn't sure if I should move forward with the installation after selecting it, or if I was supposed to format the drive.
So, I did a quick search, figured formatting was the right option, and I clicked format the drive. It then showed the drive as being all freespace (almost), and I thought great, lets get on with it, I click next, and it tells me there isn't enough space on the drive to move forward. Nothing I do will change it, so I try restarting and trying again, hoping that now it will work.
Now, however, my usb iso is no longer being recognized, and I cannot boot to the SSD of course, and so I am stuck just going into the bios and I cannot install windows. I am beyond frustrated. Did I do something to delete the drivers on the SSD or something? was format the wrong option? Why is it even an option if it just prevents you from using the drive? Is the drive ruined now?
How do I fix this? how can I boot again from my usb and get win10 up and installed?
tldr: I chose 'format' for my SSD on a new windows installation and now nothing works
thanks for any help.
