Problems with New ATI Radeon 9800 128 (non-pro)
compnut5x
7
Greetings all. I have a problem that is bugging me. I recently upgraded some parts of my pc to have speedier gameplay, but I am not getting that. Specifically, its my FPS in games that a problem. Here are my specs:
Athlon T-bird 1.2 266mhz
GA-7N400 Pro Nforce2 mobo
Generic DDR333 1GB ram (2x512 running in DDR mode)
Sapphire OEM Radeon 9800 128 non-pro
Maxtor 40 GB 2mb 7200rmp HD
Gigabit ethernet card (intel 1000/Pro)
300watt Generic Power Supply.
I have WinXP SP 1 installd
DX 9.0b
Catalyst 3.7 installed - All grapics card settings for ATI are at default
1024x768 32bit 85Htz
Latest Nforce drivers
Bios Settings are set for AGP 8x
Fast Writes enabled
Now. With a configuration like that, I dont expect to get extreme frame rates (as my cpu is the main limiting factor). But, here are some of the numbers that I am pulling in Games. I used FRAPS 99 in most games to get fps.
No One Live Forever 2 - approx 24-30 fps
Wolfenstein Enemy Territory - approx 30fps indoors, 24 outdoors
Quake2 OpenGL - 100fps
Warcraft3 Frozen Throne - 15-27 fps in movies, 35 ingame.
Unreal2 (lowest detail possible) - 20 indoor, 15 outdoor.
Aquamark3 - 15.85 fps - GPU score of 2448, CPU score of 2248
Does anyone have ANY idea why I am getting such low scores? I checked comparable scores in Aquamark3's database, and my score is the lowest of my category. The next lowest is a user with an Athlon 1.1 with 768 ram and a radeon 9800 reg, and he got 24 fps as his average.
One theory I had was that the card wasn't getting enough power and was running at reduced speed. Is there anyway to tell this? I have 2 hard drives, a cd burner, dvd drive, floppy, ide zip, graphics card, and motherboard/cup all running off a 300watt generic power supply. Is it possible that its not getting enough power? If that might be the case, is there any way to check that (software prog possibly?) I dont have a multi-meter to test voltage, and I dont have a higher PSU to swap out. Is there a formula to tell how much stuff you can connect to a power supply (like how much power each item needs in watts to tell if I am over?) Could this theory have any creedence?
Either way, ANY help from you all would be most greatly apprecated. Feel free to post your suggestions/comments and I will try them out and let you know if they work. Thanks a lot guys. Hope you can help me!
Steve
compnut5x
Robor
It appears your CPU may be holding you back but I'm not an AMD owner so I could be wrong. If it's not the CPU holding you back I would use Driver Cleaner to remove any of the stray driver files from your previous card(s).
lordtyranus2
Banned
Oct 3, 2003
300
If you have hardware doctor, you can check the voltages and see if they are where they supposed to be. With your PSU, I doubt they are.
