In my opinion, moving ONE database to another server SHOULD resolve your problems because separate databases are now on separate drives, separate systems and access to databases is through different NIC's with separate IP addresses instead of one server NIC, shared drive.
Really though, you need to analyze where the problems are originating or what actions/events result in the errors. Troubleshooting/monitoring and finding the actual problem is the first task at hand.
Are the drives good? Are network connections/connectors certified/verified and have they been retested? Is drive response slow, are workers waiting all the time for file access? What do the users say? What other problems are occurring?
File sharing problems, locks, and violations may be occuring if the file server is just running the database as a shared application instead of as a client/server application. If the applications are not client/server but shared applications and multi-user enabled, then you may need to write some script that prevents multiple user access to any same file/record. (This is the old way of preventing sharing violations and I have no knowledge of databases.)
Are you running SCSI drives on your database/file server? If not, why not?
Always run critical data on SCSI. It can managed/block bad blocks on the fly (you loose the data in blocked blocks, but continual errors don't occur), IDE/Ultar ATA CANNOT do this, even with S.M.A.R.T. You may have a bad drive in your file server. Have you checked the drives for errors (something more advanced than SCANDISK)?
Decrease contention on your file server hard drives or array. If you do use SCSI (Ultrawide, Ultra2, or even Ultra160 is fine), separate your ACCESS and your ACT databases on to separate, individual SCSI drives or different arrays (if using RAID). If you don't use SCSI, you really should bite the bullet and install SCSI with a hardware RAID controller (single channel OK, since on most Adaptec Ultra 160 RAID solutions a single channel can support 3 arrays and JBOD or 4 arrays. (These arrays should be 0,1 for speed in my opinion, not 5. For example I would run something like 2 drives RAID 0 and mirror on 1 drive twice as big. Make sure system/file caching is on another drive, not the arrays or drives where your databases are stored.)
Decrease LAN delays on your file server by using either of three methods: Increasing NIC/LAN bandwidth, load balancing on your NICs or multilinking (or all three with Intel).
I'm inclined to believe that all you need is load balancing. For this, I recommend the Intel Dual 10/100 Server NICs. (One or two or more single port NICs for your server.) Adaptive load balancing (ALB) is a breeze with Intel NICs and works with any brand Ethernet SWITCH.
(Intel 10/100 S Dual Port Server Adapter [64 bit PCI adapter!!!], PILA8472C3, $229 retail;
Intel PRO/100+ Dual Port Adapter [32 bit version] is being discontinued, and is the same price $229, PILA8472;
Or two or more 10/100 S Server Adapters [32bit PCI], PILA8470C3, $80 each.)
It's also easy to implement adaptive fault tolerance (AFT) with the Intel NICs and this also works with any brand Ethernet SWITCH. (AFT and ALB cannot be used together, except automatically by the 802.3ad standard or FastEtherchannel/link aggregation.)
Multiple Intel NIC's can also multilink in conjunction with any SWITCH that also employs the 802.3ad standard, like the Linksys dual Gigabit/24 port switch EF24G2. $460 at Provantage.com.
802.3ad acts to link multiple NICs/ports for load balancing and adaptive fault tolerance and one way full aggregate bandwidth. 802.3ad works with ALL Ethernet protocols, even the non-routed ones like NetBEUI.
-- This switch is not like the typical Linksys 'SOHO' switch, but it has a high forwarding rate, bandwidth backplane/fabric with dual Gigabit to boot. Here's the reference:
http://www.linksys.com/Products/product.asp?grid=29&prid=417
If you have the right type of CISCO or Intel SWITCH, you can also use Fast EtherChannel/Link aggregation (which is Cisco proprietary) and works similar, but better than the 802.3ad standard, by functioning as both multilinking (aggregating bandwidth full duplex, full bandwidth on linked NICs/ports) AND load balancing and fault tolerance on the same NICs to switch setup. For this, you must use the right type of NICs and either CISCO or Intel SWITCHES which have the Fast EtherChannel/Link aggregation (proprietary) capability, not just the 802.3ad standard. Intel and Cisco switches vary in price, check their websites and online vendors for the type of switch you need which must support 802.3ad AND Fast or Gigabit Etherchannel/Link Aggregation. This does not work with non-routed protocols (NetBEUI and others).
Additionally, if you have a Gigabit SWITCH, then you can add a Gigabit adapter to your loaded server and connect this to the Gigabit uplink port with cross-over cable. Most Gigabit adapters now require 64bit PCI slots.
Really though, you first need to analyze where the problems are originating or what actions/events result in the errors. Troubleshoot, monitor and find the actual problem.
Read this:
http://www.itpapers.com/cgi/PSummaryIT.pl?paperid=10045&scid=60
