Problems with Nero Under Win2k Power User
Gatsby
1,588
I can't get it to run.
It says that i need to give myself burning privaledges..
I've looked around all I can to try and find it but to no avail.
Can anyone help me?
Gatsby
DynaOne
393
It is a new install? I just installed it on W2k with a Yamaha drive and am not having any problems.
DynaOne
Kartajan
1,264
38
Nero Burning Software + Power User = BAD
Nero Burning Software + Administrator = Burn
drewski
1,482
I had this problem when I upgraded my 5.0.3.5 which came with my CDRW to 5.5.2.3
It turned out to be a problem with the Nero upgrade. They posted a new 5.5.2.3 which has worked fine for me and solved this issue. I've since gone to 5.5.2.4 which also works fine.
I don't know what version of Nero you have, but you may want to d/l the latest upgrade and give it a whirl.
