problems with my dlink DIR-615
Boo Boo
1,514
my connection keeps slowing down this is a log from my router how do i fix these issues?
I do use ABC
[INFO] Sun Jan 11 20:36:20 2009 Blocked incoming UDP packet from 80.228.184.193:39002 to 24.xx.xx.xxx:39002
[INFO] Sun Jan 11 20:36:20 2009 Log viewed by IP address 192.168.0.199
[INFO] Sun Jan 11 20:36:18 2009 Blocked incoming TCP connection request from 69.132.4.202:61955 to 24.xx.xx.xxx:57279
[INFO] Sun Jan 11 20:36:12 2009 Above message repeated 1 times
[INFO] Sun Jan 11 20:36:10 2009 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Sun Jan 11 20:36:09 2009 Blocked incoming TCP connection request from 69.132.4.202:61955 to 24.xx.xx.xxx:57279
[INFO] Sun Jan 11 20:36:08 2009 Blocked incoming UDP packet from 67.60.214.87:47900 to 24.xx.xx.xxx:59844
[INFO] Sun Jan 11 20:36:01 2009 Blocked incoming UDP packet from 189.103.69.1:26102 to 24.xx.xx.xxx:26102
[INFO] Sun Jan 11 20:35:52 2009 Above message repeated 1 times
[INFO] Sun Jan 11 20:35:38 2009 Blocked incoming TCP connection request from 70.180.153.127:59492 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:35:34 2009 Blocked incoming TCP packet from 68.147.133.209:3842 to 24.xx.xx.xxx:6881 as RST received but there is no active connection
[INFO] Sun Jan 11 20:35:33 2009 Blocked incoming TCP packet from 86.97.209.235:60436 to 24.xx.xx.xxx:6881 as FIN:pSH:ACK received but there is no active connection
[INFO] Sun Jan 11 20:35:32 2009 Blocked incoming TCP connection request from 74.197.30.103:4408 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:35:32 2009 Blocked incoming TCP connection request from 70.180.153.127:59492 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:35:32 2009 Blocked incoming UDP packet from 80.228.184.193:39002 to 24.xx.xx.xxx:39002
[INFO] Sun Jan 11 20:35:29 2009 Blocked incoming TCP connection request from 74.197.30.103:4408 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:35:29 2009 Blocked incoming TCP connection request from 70.180.153.127:59492 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:35:22 2009 Blocked incoming TCP packet from 76.28.217.15:1383 to 24.xx.xx.xxx:6881 as RST received but there is no active connection
[INFO] Sun Jan 11 20:35:20 2009 Blocked incoming UDP packet from 91.152.175.234:12480 to 24.xx.xx.xxx:62260
[INFO] Sun Jan 11 20:35:06 2009 Blocked incoming UDP packet from 189.103.69.1:26102 to 24.xx.xx.xxx:26102
[INFO] Sun Jan 11 20:34:54 2009 Blocked incoming UDP packet from 128.189.179.30:44848 to 24.xx.xx.xxx:44848
[INFO] Sun Jan 11 20:34:46 2009 Blocked incoming UDP packet from 69.230.77.22:10725 to 24.xx.xx.xxx:10725
[INFO] Sun Jan 11 20:34:45 2009 Blocked incoming ICMP error message (ICMP type 3) from 69.248.136.72 to 24.xx.xx.xxx as there is no TCP connection active between 24.xx.xx.xxx:6881 and 192.168.1.101:58215
[INFO] Sun Jan 11 20:34:39 2009 Blocked incoming UDP packet from 128.189.179.30:44848 to 24.xx.xx.xxx:44848
[INFO] Sun Jan 11 20:34:38 2009 Blocked incoming UDP packet from 90.208.123.46:37540 to 24.xx.xx.xxx:37540
[INFO] Sun Jan 11 20:34:22 2009 Blocked incoming TCP connection request from 78.3.88.202:62334 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:34:17 2009 Blocked incoming UDP packet from 189.103.69.1:26102 to 24.xx.xx.xxx:26102
[INFO] Sun Jan 11 20:34:13 2009 Blocked incoming TCP connection request from 78.3.88.202:62334 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:34:10 2009 Blocked incoming TCP packet from 78.3.88.202:62330 to 24.xx.xx.xxx:6881 as FIN:pSH:ACK received but there is no active connection
[INFO] Sun Jan 11 20:34:10 2009 Blocked incoming UDP packet from 91.152.175.234:12480 to 24.xx.xx.xxx:62260
[INFO] Sun Jan 11 20:34:07 2009 Blocked incoming UDP packet from 90.208.123.46:37540 to 24.xx.xx.xxx:37540
[INFO] Sun Jan 11 20:34:06 2009 Blocked incoming UDP packet from 189.103.69.1:26102 to 24.xx.xx.xxx:26102
[INFO] Sun Jan 11 20:34:06 2009 Above message repeated 1 times
[INFO] Sun Jan 11 20:34:02 2009 Blocked incoming UDP packet from 90.208.123.46:37540 to xx.xx.xxx:37540
[INFO] Sun Jan 11 20:34:02 2009 Above message repeated 1 times
[INFO] Sun Jan 11 20:33:59 2009 Blocked incoming TCP connection request from 24.147.98.10:3287 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:33:50 2009 Above message repeated 2 times
[INFO] Sun Jan 11 20:33:49 2009 Blocked incoming UDP packet from 128.189.179.30:44848 to 24.xx.xx.xxx:44848
[INFO] Sun Jan 11 20:33:46 2009 Blocked incoming TCP connection request from 24.192.155.72:64106 to 24.xx.xx.xxx:49255
[INFO] Sun Jan 11 20:33:40 2009 Blocked incoming TCP packet from 75.16.55.205:55610 to 24.xx.xx.xxx:6881 as RST:ACK received but there is no active connection
[INFO] Sun Jan 11 20:33:40 2009 Blocked incoming UDP packet from 128.189.179.30:44848 to 24.xx.xx.xxx:44848
[INFO] Sun Jan 11 20:33:40 2009 Blocked incoming TCP connection request from 24.192.155.72:64106 to 24.xx.xx.xxx:49255
