Problems with my abit kt7a system
DrewsNick
30
ok I dun get it was fine for near three weeks then poof.
abit kt7a raid (raid controller is dissabled)
1 gig t-bird (7.5x133/33)
crucial cas2 133 256 meg ram
a pair of maxtor drives (20 gig 7200 rpm ata 66, 8.4 gig 5400 rpb ata 33)
generic dvd
sony spressa
creative annihilator 32 meg ddr ram
linsys nic 10/100
generic sound
zoom modem
att@home cable modem
for no apparent reason it will lock up in win me and no ctrl+alt+del to get out, just have to hit reset or the power button on the back. When I start to boot up half the time it says there are no hard drives but always sees the cds. If I turn it off in back and let it sit about 5 mins sometimes it comes up ok or I gotta do that two or three times. *edit* oh when I go into the bios half the time it will not auto detect my hard drives. the wife is saying VIRUS VIRUS but that is her answer to most things that make no sense including how billy made two terms in office. *end edit*
I used the pencil to unlock it so I could drop the multiplier and up the fsb. the temp as reported by the VIA hardware monitor shows it is never hotter than 123 (might of hit 125 once) I have rebooted to see what the bios says the heat is and it is about 3 to 5 degrees hotter. so worst case scenerio is I hit as high as 135???
This was working and the most stable system I ever put up till about three days ago.
sad
437
Hi, here are a few things I would try. First, I'd redo the L1 bridges with something more permanent than pencil lead. Second, I'll make sure all plugs/connectors are in nice and tight. Three, if the above fail, I'd move the harddrives to the Highpoint connectors and leave the cdrom drives the way they are. Also, just are you have an AMD approved PS? Good luck.
Surfhead
82
DrewsNick
30
Thanks guys will try some of that next weekend when I got more time. for now I will just keep watching for other info in here.
