- Jul 22, 2005
- 2
- 0
- 0
Having some problems with multiple graphics cards in a system. Before you ask "why the hell do you have multiple cards in your system?", the answer is because I use 3 monitors. Excessive, yes, but it's the way I like to work. I use a standard AGP card with dual outs for the center and right monitors, and a generic PCI card to control the left monitor. I use this setup at work and at home and have had no problems, until now.
A few days ago, my old AGP card (Gainward nVidia FX5900) bit the dust. Started drawing vertical lines through everything while booting up, then once in windows, things would start glitching and freezing, then lockup. The PCI card ( a PNY GeForce MX 4000) was fine. I picked up a PNY nVidia 6200 last night to replace the Gainward, and although it worked fine by itself, it would not work if the PCI card was also installed.
I returned it for an nVidia 6600 this morning, and finally a Leadtek 6800GT tonight. No go. In all cases, I get the same result... if the PCI card is installed, the AGP card has a warning in Device Manager:
"This device cannot find enough free resources that it can use (Code 12)
If you want to use this device you will need to disable one of the other devices on this system."
I uninstalled every other peripheral in my system as a test, but it's got to be a conflict between the cards. The PCI card is fine by itself, and the AGP card is fine by itself, but they won't work together, despite the fact that this same system had both working together previously. I have tried setting IRQ's manually, tried different PCI slots, and everything else I could think of. My BIOS is set to recognize the AGP slot before the PCI slot. If I disable the PCI card in Device Manager, the AGP card works, but only in 4 bit depth! Even then the AGP card complains about not having enough resources.
Any ideas what's going on here?
More info:
MB: ABIT IC7-G
2.6 GHz P4
2 gigs RAM
Win XP Pro SP2
Any help appreciated!
-Eric Gooch
www.cybergooch.com
More info:
MB: ABIT IC7-G
2.6 GHz P4
2 gigs RAM
Win XP Pro SP2
-Eric Gooch
www.cybergooch.com
