I have tried virtually every solution to my problem with my new build and decided to bring it over to you smart fellows over here at Anandtech =) I just wanted to know, for anyone who knows, am I supposed to see part of the golden teeth of the SLI switch card when I put it in? My system does not post at all. I know that all my parts are working because the mobo was just RMA'd, I tested the memory and PSU on my old comp, and I even went as far as buying another CPU to see if that was the problem, but it wasn't. I tried my old 9200 SE regular PCI card in the new comp, and that didn't work, although if I'm putting in my SLI switch card incorrectly, then it shouldn't work. These are my specs: AMD Athlon 64 3000+ Venice
MSI K8N Neo4 Platinum/SLI mobo
2x MSI NX6600GT 128 mb GPU's
(2x512mb) Corsair VS PC3200 RAM
WD 120 GB 7200 RPM EIDE HD
Aopen 16x DVD-RW Drive
Xclio 450BL 450 Watt PS
So first, I would like to know about the SLI Switch card and if I'm supposed to be seeing part of the golden teeth. Secondly, I would like to know if anyone has any suggestions about my problem.
