Problems with Motherboard Socket AM3 GigaByte GA-MA790FXT-UD5P
AVY
Hello
I bought Motherboard Socket AM3 GigaByte GA-MA790FXT-UD5P + CPU AMD Socket AM3 Phenom II X4 955 BOX Black edition (HDZ955FBGIBOX) + RAM DDR3 4096M 2000MHz OCZ Flex EX (2x2048MB) Dual Channel Kit + Videocard PCI-E nVidia 9400GT 512 Mb Palit Super (NE+9400T-TD51) . I pluged its all.
BUT when I switch on motherboard, coolers are runnung, but on display I recived "No input signal". I changed videocard but the result is the same.
Can you give a hint what is wrong?
Spydermag68
2,616
99
I would check all power inputs to the board again and re seat the card.
How big is the power supply?
Welcome the Anandtech.
AVY
The power supply has nominal 400Watt
All inputs to motherboard arr correct (lamps on board are shining and coolers are woking)
jackjack
14
Do you have an 8 pin CPU power connector connected? If not , you might want to try that.. Good luck!
Puffnstuff
16,187
4,871
What ps do you have? It might not be able to handle the cold boot inrush current which is why it won't start.
