problems with Mem. in Sisoft Sandra...please help
Kintoke
Hello
Yesterday, I download Sisoft Sandra Benchmarks. Everything went ok, but when I did the memory benchmark,and my system score was ALU/RAM 187 MB/s and FPU/RAM 205MB/s. I have 128 in ram (pc100, simple Tech.), and a soyo 6vba 133 (with the apollo 133, not the 133a). So also in the benchamrks there is a duron 600 with the chipset kt133 and 128 ram, and and that system had 367mb/400mb...why???, is the motherboard the differenet, or it is just my ram???
Thanks a lot
P3-500 (katmai)
Soyo 6vba 133 (motherboard)
128 ram (two modules) Simple Technology
SbLive!
hsp modem
Viper v770 Ultra (tnt2 Ultra)
well the duron is running the ram at 133mhz, so i doubt you catch it, but if you turn on 4-way interliveing it will help a lot. if there is not an option in the bios for that then i belive you can use a third party program to do it, though im not sure what or how.
I already did that, but I had the same results. There`s a way that my ram is worst than the average, I mean, a 128 crucial ram is much more fast than a generic 128 ram??, or is my motherboard that have ap problem?
thanks
