I just formatted and did a clean install of win2k, After I noticed this problem in windows me.  I have a cable modem and am always connected to the internet but on my main computer if I leave it idle for 5 min or sometimes less time, the interenet connection dies.  The only way i have found to fix the problem is to disable the lan connection and then re-enable it.  After that the connection coems right back.  I have all my power setings disabled and i think they are all disabled in the bios as well. I have tried a different card from another computer and that card works the same, but in the other computer i never have any connectivity problems.  Granted they are the same SMC cards.  Could it be that my computer does not like the SMC cards?  Is there anything in my bios I could be missing?
System:
AMD Athlon 650
192MB Ram
Ausus K7M Mobo
30gig HD
SMC 10/100 Network card
Sblive platinum
viper 550 w/riva tnt drivers
thanks
			System:
AMD Athlon 650
192MB Ram
Ausus K7M Mobo
30gig HD
Sblive platinum
thanks
