I have the current setup;
MSI K7N420D (nForce)
Athlon XP 1800+ (not overklocked)
1 Stick of Kingston DDR 256MB ram
MSI GeForce 4 Ti 4200 128 MB
Realtek Ethernetcard (since the internal networkcard on the MB does not work with my HUB).
1 IBM Deskstar 80GB
1 IBM Deskstar 40GB
Asus DVD E612
LiteOn CD-Rw
Codegen 300X (300W PSU, with 165W on 3,3V + 5V)
Windows XP Professional (have done numerous updates from windows update)
Detonator 30.30
MSI Chipset drivers 2.29
The problem is as follows;
When i play games (it has happened during use of Virtual Dub too) i sudden gets a hardlock, the machine freezes or the screen just goes black. It is totally random and can occur at any time. Sometimes the machine works for minutes, other times it works for hours.
I have tried the following solutions and have run of options;
1. Different versions and manufacturers of nForce chipset drivers.
2. Installing win XP without APIC.
3. Borrowed and tried an Enermax 550W PSU.
4. Tried Detonator 29.42, 28.40, 30.82, 30.30.
5. Changed my CPU heatsink which dropped my CPU temp from 50 to 42.
6. Chipset heat - Removed heatsink and checked the thermal conductivity, no problem there, so its not causing it. The chipset is _not_ overheating.
7. Removed AGP card and ran on internal. Nope, neither of the AGP cards (internal or external) caused any problems.
8. Removed all other expansion cards.
9. 3 reinstallations of windows XP, does not seem to be Win XP itself that causes the problem.
10. Flash bios from 2.4 back to 2.3, nope, same.
11. Flash bios from 2.3 to 2.6, same so i flashed back to 2.4.
12. Exchanged powersupply to a brand one (AOpen 300W), no change.
13. Disabled onboard audio and inserted an SB Live. I suspect that the problem is caused by the onboard audio. But as i write this i have yet to test if it runs stable with the SB Live (drivers take _quite_ a while to download with 56K modem).
If somone knows how i could fix this and enjoy the onboard audio that have worked earlier, please help. Im open to suggestions since ive run out of options, i do not know anything more i can test.
1 IBM Deskstar 80GB
1 IBM Deskstar 40GB
Asus DVD E612
LiteOn CD-Rw
Detonator 30.30
