PRoblems!!! with Hyper-Threading on ASUS P4C800 DLX!!! HELP!!!
toilet
People, I have a serious problem with my CPU usage on the task manager!!!.. Well I run all kingd of Programs and work perfectly but today I install the 3D Studio MAX 5.0 and Start to have a lot of CPU usage. SO I quit the 3DS MAX and he hight CPU usage not change !!.. It´s at 50% of CPu usage, after I exit the program. So know I don´t running any program and the usage is on the 50% and the HD led is active ...
If I log out and log in.. this not change .. the only thing that I can do for repair the usage is to restart the machine...
My machine is:
windows XP
install SP1
CPU P4 2.4 800FSB
P4C800 Dlx ( bios 1008 )
2x512Mb DDR400 OCZ
Saphire 9700 pro ( catalist 3.4 )
WD800JB 8mb buffer
CDW
Zip
DVD
I dont install DX 9 yet
But the problems is only with the 3D Studio Max 5.0 ... ( I install the 3D Studio max 4.2 and do the some with the CPU Usage and the HD led ) !!!!!!
What is the problem?? I forget to install something?? Someone can help me!!!
tks
in the TASK MANAGER > PROCESS i have hight numbers in:
>system Idle Process 45
>System 30
>Winlogon.exe 41
But this when I exit the 3DMX ... WHen I restart the machine all things are OK..
I run another Programs like Photoshop 7.0 ore Illustrator 10 and I don´t have any problem!!!
Are you running any monitoring software on your pc when the CPU useage is that high? Did you download a distributed computing program onto your PC? like SETI screen saver or anything like that?
~wnied~
