- Apr 28, 2004
- 1,187
- 0
- 76
I am having another with Handbrake this time after it updated to the new version. This time it is dropping frames in the encode. I don't know if I missed a setting some where or if the input file is bad. It says something about an Mpeg2 tag botch (Which I have no idea to what that means) So is there a way to get it to work properly again? I am using MPEG Video Wizard DVD 5.0 to edit out the commercials.
Thanks
Here is one encode log
Thanks
Code:
HandBrake 0.9.9.5470 - 32bit Version
OS: Microsoft Windows NT 6.1.7601 Service Pack 1
CPU: AMD Athlon(tm) II X4 635 Processor
Ram: 12284 MB, Screen: 1920x1080
Temp Dir: C:\Users\My Name\AppData\Local\Temp\
Install Dir: C:\Program Files\Handbrake
Data Dir: C:\Users\My Name\AppData\Roaming\HandBrake\HandBrake\0.9.9.5470
CLI Query: -i "D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg" -t 8 --angle 1 -c 1 -o "D:\Encoded Videos\Safe Deposit Krabs (2).mkv" -f mkv --deinterlace="slower" --denoise="weak" --deblock=5 --strict-anamorphic --modulus 16 -e x264 -q 20 --vfr -a 1 -E faac -6 dpl2 -R Auto -B 160 -D 0 --gain 0 --audio-copy-mask none --audio-fallback ffac3 -x ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 --verbose=1
User Query: False
[22:53:07] hb_init: starting libhb thread
HandBrake 0.9.9 (2013051800) - MinGW i686 - http://handbrake.fr
4 CPUs detected
Opening D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg...
[22:53:07] hb_scan: path=D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg, title_index=8
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg/BDMV/index.bdmv
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg/BDMV/BACKUP/index.bdmv
libbluray/bluray.c:1725: nav_get_title_list(D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg) failed (01A905F8)
[22:53:07] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[22:53:07] dvd: not a dvd - trying as a stream/file instead
[22:53:07] file is MPEG Program Stream
[22:53:07] Probing 1 unknown stream
[22:53:07] Probe: Found stream mpeg2video. stream id 0xe0-0x0
[22:53:07] Found the following streams
[22:53:07] Video Streams :
[22:53:07] 0xe0-0x0 type MPEG2 (0x2)
[22:53:07] Audio Streams :
[22:53:07] 0xc0-0x0 type MPEG2 (0x4)
[22:53:07] Subtitle Streams :
[22:53:07] Other Streams :
[22:53:07] stream id 0xc0 (type 0x4 substream 0x0) audio 0xc0
[22:53:07] scan: decoding previews for title 1
[22:53:07] scan: audio 0xc0: mp2, rate=48000Hz, bitrate=200000 Unknown (MPEG2) (2.0 ch)
[22:53:07] scan: 10 previews, 704x480, 29.970 fps, autocrop = 56/60/2/0, aspect 4:3, PAR 10:11
[22:53:07] stream: 63 good frames, 0 errors (0%)
Scanning title 1 of 1, preview 10, 100.00 %[22:53:07] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg
+ duration: 00:10:58
+ size: 704x480, pixel aspect: 10/11, display aspect: 1.33, 29.970 fps
+ autocrop: 56/60/2/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:10:58
+ audio tracks:
+ 1, Unknown (MPEG2) (2.0 ch) (iso639-2: und)
+ subtitle tracks:
[22:53:07] 1 job(s) to process
[22:53:07] starting job
[22:53:07] Yadif Deinterlace thread started for segment 0
[22:53:07] Yadif Deinterlace thread started for segment 1
[22:53:07] Yadif Deinterlace thread started for segment 2
[22:53:07] Yadif Deinterlace thread started for segment 3
[22:53:07] work: sanitizing track 1 mixdown Dolby Pro Logic II to Stereo
[22:53:07] sync: expecting 19743 video frames
[22:53:07] job configuration:
[22:53:07] * source
[22:53:07] + D:\Video Data\Recorded TV Shows\Safe Deposit Krabs (2).mpg
[22:53:07] + title 1, chapter(s) 1 to 1
[22:53:07] * destination
[22:53:07] + D:\Encoded Videos\Safe Deposit Krabs (2).mkv
[22:53:07] + container: Matroska (.mkv)
[22:53:07] * video track
[22:53:07] + decoder: mpeg2
[22:53:07] + bitrate 6000 kbps
[22:53:07] + frame rate: same as source (around 29.970 fps)
[22:53:07] + filters
[22:53:07] + Deinterlace (ffmpeg or yadif/mcdeint) (3)
[22:53:07] + Framerate Shaper (0:27000000:900900)
[22:53:07] + Deblock (pp7) (5)
[22:53:07] + Denoise (hqdn3d) (2:1:2:3)
[22:53:07] + Crop and Scale (702:364:56:60:2:0)
[22:53:07] + source: 704 * 480, crop (56/60/2/0): 702 * 364, scale: 702 * 364
[22:53:07] + strict anamorphic
[22:53:07] + storage dimensions: 702 * 364, mod 0
[22:53:07] + pixel aspect ratio: 10 / 11
[22:53:07] + display dimensions: 638 * 364
[22:53:07] + encoder: H.264 (x264)
[22:53:07] + options: ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0
[22:53:07] + quality: 20.00 (RF)
[22:53:07] * audio track 1
[22:53:07] + decoder: Unknown (MPEG2) (2.0 ch) (track 1, id 0xc0)
[22:53:07] + bitrate: 200 kbps, samplerate: 48000 Hz
[22:53:07] + mixdown: Stereo
[22:53:07] + encoder: AAC (faac)
[22:53:07] + bitrate: 160 kbps, samplerate: 48000 Hz
[22:53:07] reader: first SCR 146 id 0xe0 DTS 12288
[22:53:07] encx264: min-keyint: 30, keyint: 300
[22:53:07] encx264: encoding with stored aspect 10/11
[22:53:07] encx264: Encoding at constant RF 20.000000
x264 [warning]: --psnr used with psy on: results will be invalid!
x264 [warning]: --tune psnr should be used if attempting to benchmark psnr!
x264 [info]: using SAR=10/11
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSEMisalign LZCNT
[22:53:07] mpeg2: "Chapter 1" (1) at frame 0 time 3003
x264 [info]: profile Main, level 3.0
[22:53:07] sync: first pts is 3003
[22:54:56] mpeg2 tag botch: pts 8093085, tag pts 8060052 buf 00000000
[22:55:02] mpeg2 tag botch: pts 8582574, tag pts 8549541 buf 00000000
[22:55:03] mpeg2 tag botch: pts 8639631, tag pts 8606598 buf 00000000
[22:55:09] mpeg2 tag botch: pts 9072063, tag pts 9048039 buf 00000000
[22:55:14] mpeg2 tag botch: pts 9429420, tag pts 9396387 buf 00000000
[22:55:55] mpeg2 tag botch: pts 12408396, tag pts 12375363 buf 00000000
[22:55:55] mpeg2 tag botch: pts 12477465, tag pts 12450438 buf 00000000
[22:57:48] mpeg2 tag botch: pts 20606586, tag pts 20573553 buf 00000000
[22:58:12] mpeg2 tag botch: pts 22384362, tag pts 22360338 buf 00000000
[22:58:15] mpeg2 tag botch: pts 22564542, tag pts 22540518 buf 00000000
[22:58:35] mpeg2 tag botch: pts 23993970, tag pts 23966943 buf 00000000
[22:59:31] mpeg2 tag botch: pts 28129101, tag pts 28096068 buf 00000000
[23:00:11] mpeg2 tag botch: pts 30933903, tag pts 30909879 buf 00000000
[23:00:22] sync: video time didn't advance - dropped 1 frames (delta 0 ms, current 31750719, next 31753722, dur 3003)
[23:00:29] mpeg2 tag botch: pts 32279247, tag pts 32246214 buf 00000000
[23:00:40] mpeg2 tag botch: pts 33090057, tag pts 33063030 buf 00000000
[23:00:57] mpeg2 tag botch: pts 34366332, tag pts 34333299 buf 00000000
[23:01:03] mpeg2 tag botch: pts 34798764, tag pts 34774740 buf 00000000
[23:01:45] mpeg2 tag botch: pts 37741704, tag pts 37717680 buf 00000000
[23:02:21] mpeg2 tag botch: pts 40468428, tag pts 40441401 buf 00000000
[23:02:53] mpeg2 tag botch: pts 42972930, tag pts 42948906 buf 00000000
[23:03:13] mpeg2 tag botch: pts 44498454, tag pts 44465421 buf 00000000
[23:03:32] mpeg2 tag botch: pts 45822777, tag pts 45798753 buf 00000000
[23:04:08] mpeg2 tag botch: pts 48423375, tag pts 48399351 buf 00000000
[23:04:25] mpeg2 tag botch: pts 49690641, tag pts 49657608 buf 00000000
[23:04:38] mpeg2 tag botch: pts 50657607, tag pts 50630580 buf 00000000
[23:04:53] mpeg2 tag botch: pts 51765714, tag pts 51741690 buf 00000000
[23:05:06] mpeg2 tag botch: pts 52762710, tag pts 52729677 buf 00000000
[23:05:16] mpeg2 tag botch: pts 53486433, tag pts 53453400 buf 00000000
[23:05:37] mpeg2 tag botch: pts 54966912, tag pts 54942888 buf 00000000
[23:06:04] mpeg2 tag botch: pts 57020964, tag pts 56993937 buf 00000000
[23:06:29] mpeg2 tag botch: pts 58885827, tag pts 58861803 buf 00000000
[23:06:35] reader: done. 1 scr changes
[23:06:37] work: average encoding speed for job is 24.420879 fps
[23:06:37] sync: got 19742 frames, 19743 expected
[23:06:37] render: lost time: 0 (0 frames)
[23:06:37] render: gained time: 0 (0 frames) (0 not accounted for)
[23:06:37] mpeg2 done: 19743 frames
x264 [info]: frame I:208 Avg QP:18.35 size: 29720 PSNR Mean Y:46.22 U:49.51 V:49.97 Avg:47.07 Global:46.33
x264 [info]: frame P:8169 Avg QP:21.09 size: 5855 PSNR Mean Y:43.13 U:47.42 V:47.81 Avg:44.16 Global:43.71
x264 [info]: frame B:11364 Avg QP:23.55 size: 671 PSNR Mean Y:42.88 U:47.60 V:47.92 Avg:43.97 Global:43.60
x264 [info]: consecutive B-frames: 9.1% 18.3% 72.6%
x264 [info]: mb I I16..4: 19.8% 0.0% 80.2%
x264 [info]: mb P I16..4: 1.5% 0.0% 4.1% P16..4: 38.2% 8.9% 6.6% 0.0% 0.0% skip:40.6%
x264 [info]: mb B I16..4: 0.7% 0.0% 0.2% B16..8: 7.5% 2.7% 0.2% direct: 3.3% skip:85.3% L0:37.2% L1:55.6% BI: 7.2%
x264 [info]: coded y,uvDC,uvAC intra: 62.9% 82.1% 56.3% inter: 9.1% 11.9% 1.5%
x264 [info]: i16 v,h,dc,p: 29% 39% 16% 16%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 26% 15% 5% 6% 6% 7% 5% 7%
x264 [info]: i8c dc,h,v,p: 32% 33% 22% 13%
x264 [info]: Weighted P-Frames: Y:0.4% UV:0.4%
x264 [info]: ref P L0: 76.8% 5.3% 17.9% 0.0%
x264 [info]: ref B L0: 73.2% 26.8%
x264 [info]: ref B L1: 91.6% 8.4%
x264 [info]: SSIM Mean Y:0.9888737 (19.536db)
x264 [info]: PSNR Mean Y:43.020 U:47.550 V:47.896 Avg:44.081 Global:43.666 kb/s:748.52
[23:06:37] mp2-decoder done: 0 frames, 0 decoder errors, 0 drops
[23:06:37] mux: track 0, 19741 frames, 61626286 bytes, 748.39 kbps, fifo 4096
[23:06:37] mux: track 1, 30880 frames, 13174208 bytes, 159.99 kbps, fifo 8192
[23:06:37] stream: 244842 good frames, 0 errors (0%)
[23:06:37] libhb: work result = 0
Encode done!
HandBrake has exited.
