I have the following problems with my system.
1. GA-7VRXP will not run at 133 FSB. It runs fine at 100. I have left the voltage at default, increased it, with no luck at 133
I have had the 1Ghz for over a year, and it will clock at 7.5*133 with ease on other boards, so I know the CPU is not bad.
2. Windows ME is a disaster of an installation. I can get it to install initially, but as I install drivers and PCI cards, it eventually crashes so hard, I have to reformat the HD and start over. Sometimes, I don't install anything but the basic CPU, Memory, and video card and it still becomes so corrupt, it wont even boot in safe mode. I have installed WinME on another mobo, with the same components, with no hitch.
3. The add hardware screen freezes and stops responding EVERY time now. I can't even install the motherboard onboard audio drivers or ANY other PCI cards because of the add hardware freezing up. The update hardware settings with a % complete takes forever, usually between 2-5 minutes to complete the process.
4. I cant stand the post check where it tries to detect a MBUltra 133 device. Is there a way to disable this and still use my U100 HD?
I know the all the components except the motherboard are good, as I have had them all for over a year.
Any recommendations before I contact Gigabyte, and then MS for tech support?
GA-7VRXP Motherboard
Crucial PC2100@266 256MB #CT3264Z265
1Ghz Axia Tbird
Asus V6600 256 Geforce1 Nvidia Detontator V28.32
Antec 1040B with 400W PP412X PSU
Windows ME
3COM 10/100 PCI NIC
WD 60GB HD 7200RPM @100
Toshiba SD-M1612 DVD-ROM
1Ghz Axia Tbird
Windows ME
3COM 10/100 PCI NIC
