Problems with Direct3D, plz help.
Neon01
I recently purchased a leadtek geforce2 256 pro for my machine because my viper II driver support in Win2k wasn't cutting it. Now it looks like the geforce isn't fixing any of my problems. I have severe slowdown in programs like UT, Unreal (original), dues ex, etc. whenever i try to use direct3d. Also strange is that it makes the gamma go way up, and this cannot be corrected within the program, AND my mouse is SUPER sensitive when in the programs. Background info, I have an athlon 850, 256 megs of pc133 ram, 30 gb seagate 7200 rpm, and the geforce2 pro. I'm using the current drivers on nvidia's site (detonator 3?), and directx 8.0. What am I doing wrong? OpenGL seems to work great!! when I can get it to work with a program. Any comments/suggestions would be appreciated!
try differnt drivers, and did you do a fresh install with your new card? or at least re-install the games? UT never worked right for me till i re-installed it after i got my radeon(it thought i still had my V3 in there)
Yes, save your backup directories and reinstall UT, then copy your saves back.
You probably have the old files in UT system files.
