Problems with Detonator 12.41 custom color settings under Win2k
swrobel
20
I'm having trouble with getting my custom color settings to stay under Windows 2000. When I play games, I want to use a higher gamma level, so I have defined a custom color setting and use the quicktweak icon to change color settings. Unfortunately, the custom color setting never seems to stick when I fire up a fullscreen game, and it pretty much defeats the purpose. Does anyone know of a solution to this problem?
This is the place to discuss the latest computer hardware issues and technology. Please keep the discussion ON TOPIC, and covering computer hardware ONLY.
AnandTech Moderator
lilnnjaboy
478
there is a problem with that quick tweak thing.. I did the custom color settings and I don't use the quick tweak and it stays.
Another solution is if you have Adobe photoshop 5.0 or above, they have a adobe gammna program that is loaded in your control panel. You can use that to adjust the gamma so you can see those campers in the dark corners =).
