Problems with Debian installer
Sep 16, 2004
86
I am trying to install Debian on a very old computer. The PC has a 200mhz chip. It boots up from the cd-rom, I see the debian logo to press f1 or enter to boot. Then, BAM, I get a error message saying "Unable to handle kernel paging request at virtual address fffedfdf". Then I get a bunch of jibber jabber and then "<0>Kernel panic: Attempted to kill the idle task!
In idle task - not syncing". Is it a hardware or software problem. I will be monitoring this topic for the next hour. Any help will be greatly appreciated.
cleverhandle
3,566
Sounds like you may need some unusual boot parameters to deal with the older hardware. What kind of chip and motherboard do you have exactly?
Sep 16, 2004
86
The chip is a pentium, chipset is i430vx and the mb is a unknown brand. I wish I knew. It is a really old PC. I think the mb is of AT variety. the power switch is hard wired to the power supply. And, the keyboard connector is a fat connector not the ps/2 styled little connector.
cleverhandle
3,566
Hmm... that sounds reasonably OK. Nothing too weird like an old Cyrix chip or something. Have you checked the memory against memtest86? Can the system boot up a plain DOS boot disk?
It could be something trickier, but I'd try to rule out simple hardware problems first.
Sep 16, 2004
86
I don't know about the dos boot disk. I have no floppy drive. i would not know how to run memtest86, there is no os on the hd.
Sep 16, 2004
86
I figured it out. Thanks cleverhandle for taking the time to help. It was a hardware problem. Two different types of RAM was installed. I should have noticed it before but, I didn't. It is installing now. Again, thank you.
