Battousai001
Just wanna share my experience with this board I got, and hopefully you guys might share some suggestions.
I just got a Redfox/Biostar M7NCG 400 Socket A motherboard last week, the board has an NVIDIA nForce2 IGP / MCP chipset, has an integrated GeForce 4 MX GPU with up to 128MB Frame Buffer, onboard sound, etc. I have installed 384 MB DDR RAM (128MB + 256MB) both are DDR266.
Here's my story and the problems I encountered:
I used a Duron 750Mhz. I had difficulties during the first time I installed and set-up the board, I cant get the board running (no screen, no boot up) after fiddling with the RAM I finally able to get the board running. (I never knew what is the cause of the problem, I cant conclude if its just a loosed ram or wrong jumper cause I made sure I installed everything properly, but after many trials I was able to get the board running and I added additional 256MB RAM)
After that I tried re-installing WinXP Pro, everytime winxp is about to install the files the system hangs goes to blue screen and restarts itself, it went that way for two days until I discovered that it was caused by the processor overheating due to improper installation of heatsink.
After the installation of Windows I noticed that the Windows loading screen the winxp logo with the loading blue bars is a little bit distorted and it takes a little bit long to load. I dont know if its with the harddisk cause the hdd simultaneously gone haywire with after installing the OS. What happened with the hdd is that it is being detected int he CMOS setup as as a different version and I needed to auto-detect the the disk twice in order for the correct version to be detected after a while I figured it out and fixed my disk by changing the jumpers to cable select and used a new IDE cable (the IDE cable instantly became busted simultaneously with the HDD with no apparent reason, and now I think the hdd is a little bit damaged because the jumper setting for master drive is not working anymore)
After all that, I managed to get everything work perfectly and smoothly. Now the only problems I have are:
1. Why is the speed of my processor not properly listed? it is clocked at 742-745Mhz when it should be at 750Mhz? is there something wrong with the board or should I change the settings? and Where can I find a bios update with this board? I just downloaded some updated bios on the board manufacturer Biostar/Redfox, but the onboard bios update utility detects the new bios as different
2. Is there an issue with PC266 RAMs? whats better to use the PC333 or the PC266 on this board?
3. Whats wrong woth WinXP's loading screen? and why did it take longer to load compared to my older/slower board?
Any comments on the M7NCG 400? And whats the good things about this board?
