I recently purchased the Asus CUSL2 MB with a PIII 866 CPU and I'm having problems with Microsoft's Optical Explorer mouse. This mouse is physically connected to the USB port and I can't get Windows (Win98 Second Edition) to load the MS Intellimouse driver. It loads a driver called "HID-Compliant Mouse" as the primary driver. The mouse seems to works okay, but during shutdown the mouse starts
flashing and then the normal shutdown sequence locks up. While locked up, if I unplug the mouse from the USB port the computer will continue with its normal shutdown. Called MS Tech support and after a hour of trying things they gave up and said it was a MB problem with the USB port. I even gone so far as . . . reseting the BIOS to default, re-formating the HD, re-installing Windows, loading Asus's latest drivers and all with only the video card, mouse and CDRom installed, nothing seems to work
[Any suggestions ??]
