- Jan 18, 2005
- 40
- 0
- 0
Was all excited to have all the parts for my new rig! About halfway through after the motherboards in we try connecting the PSU and it doesn't fit...My friend who was doing most the building said it was because it wasn't EPS12? He had an adapter that we used so I thought that would be ok. But then about halfway through the windows install it just dies and powers off, it did it multiple times, not at the same point of the install either. We checked the temperatures and its not that, so were 90% sure it would be the power supply. Anyone else have experience with this? Here is my rig:
MOTHERBOARD - ASUS "A8N-SLI Deluxe" nForce4 SLI Chipset Motherboard For AMD Socket 939 CPU -RETAIL
CPU - AMD Athlon 64 3500+, 2.2 GHz, 512KB L2 Cache 64-bit Socket 939 Processor - Retail
VIDEO - 2X BFG GeForce 6800 GT OC 256MB GDDR3/PCI-E/TV-Out/Dual-DVI (Retail Box) IN SLI
PRIMARY DRIVE - 2X Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only IN RAID-0
AUXILIARY DRIVE - Maxtor (6B300S0) DiamondMax Plus 10 300GB SATA 7200 RPM 16MB Cache
CASE - Lian-Li Silver ATX Full Tower Case, Model "PC-V2000A" -RETAIL
OPTICAL - NEC 16X Double Layer DVD±RW Drive, Black, Model ND-3520A BK, OEM
PSU - Enermax Noisetaker 600Watt 'EG701P-VE SFMA' Retail
MEMORY - OCZ EL Platinum Revision 2 Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-3200 - Retail
I guess I'm just going to send the PSU back for a refund and try to find another one locally since I don't really want to wait so long. Anyone know if CDW or any local stores sell high quality PSUs? It must work with PCI-E and be pretty high wattage. What kind has been tested to work with this kind of setup, anyone have personal expereince?
