Problems with ASUS A7v333 Mobo, "System Failed Memory Test"...read on
fumbduck
4,349
I have an asus a7v333 mobo, and i have everything plugged in, i have built many computers before, so i've tried lots to fix it.
I have a stick of corsair ddr ram, and when i stick in in every slot, i still get the "System failed memory test" error from the computer(it shouts it at me).
I thought it might be my ram, so i went and bought another stick, but to no avail, same error and everything, tried it in every slot.
Does anybody else have/had this problem? or have a way to fix it?
All help/criticism is appreciated, thanks.
DeschutesCore
360
I've RMA'd several of the A7V-333's due to the 1v + bug, but I've never heard of that one happening on those boards. Sound like she's pooched. Try to force a cmos reset and don't forget that a lot of Asus boards can be reset to default by holding down the ctrl key while you power up, don't let it go until you see the post.
DC
fumbduck
4,349
well i dont even get any output to monitor, it just boots up and immediately starts screaming :System Failed Memoru Test:.. i need help! should i RMA?
