Everything is running at stock or underclocked (E6300 @ 1.76ghz, DDR400 at DDR333 as a result to conform to SPD timings rather than chance the DDR355 at unknown CAS specs)
The 3.3v rail is sagging to 3.25 typically with lows of 3.23 and occasioanlly 3.2v. I had this problem before and had to RMA the power supply (it was a Antec basic 380W, they sent me a new EA430).
The 380W PSU's 3.3v was barely giving 3.15-3.20 by the time I had to RMA it...but it showed a fine 3.3v rail in another system...
I remember the 775i65G on the new PSU it started off around 3.28v in BIOS (speedfan reported it as 3.26).
There was a time during the RMA that I used another PSU from an old P4 system. It reported the highest 3.3v rail I saw (3.29/3.30 in bios, 3.28 by speedfan). But I was way underclocked to 1.4ghz to enable the onboard video, (didn't have a pci express power connector for my AGP HD2600). I didn't run it long enough to see if it would start sagging too...
I don't see any bloated, leaking or popped capacitors on the board and it was otherwise stable for over a year on the EA430 until yesterday when it had trouble posting after a reboot.
Is it possible the motherboard is slowly killing this PSU?
I think multimeter reads were showing as normal before in all cases...and thought perhaps it was just the ATX power connector but it shows no signs of overheating/burning (I remember seeing singed 5v connectors back in the day on some bad boards killing PSUs...)
