I've got a compaq desktop (it was a flaming hot deal at compusa a while ago - it's a A64 3400+ that I've upgraded lots).
It's got a Leadtek 6800 AGP card. I was able with stock cooling (the massive leadtek copper HSF on both sides of the card) to unlock it nicely.
I just bought a NV silencer to make it run a bit quieter and exhaust the heat. Installed it, everything seems fine. Boot the computer - there's some minor screen glitches. After a few minutes, it reboots on its own.
Pulled the card out and removed the cooler. Everything looks fine - good spread of thermal goo on the GPU, etc. The silencer has pads to hit the ram and it looks like they do (hard to see for sure).
Put everything back together, and it's still the same. I popped into the bios to see how the CPU temps are. Seems fine. There are glitches even in the bios though - a few letters being the wrong colors. Maybe only 6 or so on the whole screen.
If I leave it in the bios, it'll sit for a long time w/o rebooting. As soon as I go into windows, it lasts just a minute or two and it reboots. It does seem to be heat related, because if the computer's been off a while it'll last a bit longer.
Any ideas?
Any ideas?
