Problems with an old TV out on a TNT
eddiebel
I have a old TNT video card and I just put it in my crappy computer just to use the TV out from it. I used the newest nvida drivers, but for the life of me I can't get the dam TV out to work. It is in the menu but I just can't select it. (yes it is plugged into the tv). Can anybody help?
Demon-Xanth
20,551
There are some other option boxes you have to check, there's a resolution limit, and when the TV is selected the monitor will be disabled.
Antoneo
3,911
Have you tried older drivers like the 6.5's? older drivers tend to work better than the newest ones. You can find them at:Reactor Critical. Hope this helps.
