So I recently was given a computer for free and I've been upgrading it into a little media center PC for the living room.
One thing it badly needed was a new CPU. It had a single core AMD Sempron 3200+ and the CPU usage would be pegged at 100% during use. So I bought a Phenom X3 8650 to replace it.
Thing is, 9 times out of 10 when I power it up, I get an endless series of BIOS beeps. But if I keep powering it on and off it will eventually post and boot into Windows just fine. I checked the RAM and it is seated correctly. I also swapped in a beefier power supply thinking that maybe that the Phenom was pulling too much juice but it didn't have any effect.
The motherboard is a Gigabyte GA-M61PM-S2 (http://www.gigabyte.com/products/product-page.aspx?pid=2373#ov) and according to the CPU support list (http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=2373) the 8650 IS supported. I flashed the BIOS to the newest revision (F9D) before upgrading the CPU.
What's going on here? I know the motherboard is good because it worked fine before and the CPU works fine when I can get it to POST. Does the board just not support that CPU (even though the website says it does)?
Am I missing something here? How can I get this mobo and the CPU to play nice with each other?
