Asus P3BF, P3 700E@933, Diamond MX300 sound card with latest drivers.
Sometimes when I boot up and enter windows I get a lot of static and distorted noise instead of entering windows sound and sound does not work. Then I either reboot or restart to dos and enter back in windows and the sound is fine. The PCI divider is at 1/4 so the PCI bus is running at 33Mhz spec. BTW this never happened on 100MHZ FSB.
What could be the problem?
Thank You.
Thank You.
