WarDemon666
I bought a Vantec NST-250U2 laptop drive enclosure and im having problems with it.
It works great except for one thing. If the enclosure is plugged in before windows boots, the drive is not found in windows. But if I wait for windows to boot (as soon as i can see the mouse) the drive is recognized properly.
If I open the device manager I see "The device cannot start. (code 10)" when plugging the drive in before windows boots.
Simply unplugging the drive and plugging it back in resolves this problem. I am using the supplied Y cable on two different USB ports, i am sure it is getting enough power. This problem happens with ALL computers ive tried it on (5 different computers, all running winxp, SP1 and SP2 still the same problem)
Ive also tried disabling / uninstalling all the usb devices after a boot and it still says "The device cannot start. (code 10)". The only way I can get the drive to start properly again is to remove the cable, wait for the drive to spin down, and plug it back in.
Ive noticed that it only does this on a shutdown. If i restart windows the drive is still recognized on boot.
I have a fujitsu 80gb hard drive in the enclosure.
What could be causing this problem?
Any help would be greatly apprechiated.
Thanks
Thanks
