Problems with 7VRXP! Help?
Derfo
More problems with 7VRXP!
I specially paid more money to get RAM of CL 2.0 rather than of 2.5
It turns out that whenever I switch Latency to 2 in the BIOS, XP & 2000 both hoze up. Programs generate errors and ultimately the machine just freezes!
Also has anybody else had a problem with the computer not shutting down? I installed XP and the computer would restart instead of shutting down.
Help?
-Derfo
:disgust:
AMP XP 1800+, 512MB OCZ 2.0 RAM, IBM 80gb HD, WD 12gb HD, Plextor 12/10/32 Burner, Sony 40x CDROM, Zip, SoundBlaster 5.1 Gamer.
Thanks a ton.
Guess going cheap has its pitfalls! Might just have to run it at Cas of 2.5
I have an Enlight 300W power supply.
The 7VRXP sucks. I have one too and I'm returning it for a MSI KT3 Ultra-ARU. It has issues with power management and, in some cases, missing capacitors.
Go check out the forum over at viarena. Lots of people are having problems just like yours. Mine is with the RAM and my GF4 Ti4200.
Tried the board with these settings and things have stablizied a bit.
Newegg has NO return policy. Sucks!
top performance😀isabled
fast command:ultra
configure sdram by spd:enabled
sdram frequency:333
sdram cas# latency😀on't worrie because the"config by spd takes care of this"
sdram command rate:2t command(make sure 100% this is at 2"
agp mode:4x
agp comp driving:auto
agp fast write:enabled
agp aperture size:128
agp read synch:enabled
pci delay trans:enabled
intergrated peripherals:
onboard midi port😀isabled
onboard game😀isabled
onboard sc interface😀isabled
onboard ms/sd interface😀isabled
onboard sound chip😀isabled
also disable anything else you don't use
agp 1.5v
memory 2.6v
vcore +7.5%
don't press cntrl f1 when changing settings
