Hello,
I am a first time builder, having some issues with my first build. I am trying to determine if the problems are related to the P8P67 Pro, or if I have simply done something wrong: Specs are as follows:
Intel Core i7 2600K (stock clocks)
P8P67 Pro
2GB PNY Ram (waiting on 16GB of Ripjaws (F3-10666CL9D-8GBRL,1333 MHz) to arrive but wanted to test the system with some spare DDR3)
64GB Crucial SSD (boot drive)
640GB WD Black Caviar HDD
Corsair TX850w PSU
AMD Radeon 6850
Windows 7 Pro 64-Bit
Since using the system, I have had three instances of the computer crashing. Once during web surfing, once during program installation, and once during a game (so, at a variety of load levels). When this happens, the HDD activity light on the case (CM Storm Scout) remains lit and the mouse, keyboard, and screen become unresponsive. I have checked the temps (via SpeedFan, Asus Utilities, and HWMonitor, and all return a CPU idle of around 29C and 40C under load (GPU holds at around 37C, mobo at 28C). Windows Memory Diagnostics have also returned no issues. I did not run MemTest86+ as it does not fully support Sandy Bridge.
Here are some odd (to me anyway) circumstances that have surrounded this activity:
1. The issue cropped up after I upgraded the bios to 1003 from the factory installed version (0402 I think).
2. When I turn the computer on, it seems to "rev" once (lights come on, fans spin) and then shuts down before coming on in full a few seconds later.
3. There is a large discrepancy between cpu temps in BIOS and those within Windows (46C to 48C in BIOS vs. the numbers listed above). As the CPU fan only spins at about 1000 RPMs most of the time and I cannot detect significant heat from the case, I am fairly confident that I do not have an overheating issue.
4. A large green light on the board next to "CLRTC" is lit constantly.
I believe I may be experiencing a RAM compatibility issue or just simply not have enough of it, as half of the system RAM seems to be in use according to Task Manager. Any advice from those more experienced at this than myself would be helpful. I thought I did my homework on PC building but is likely that I have overlooked something simple/obvious.
Thanks,
Wcladley
P8P67 Pro
Corsair TX850w PSU
AMD Radeon 6850
Thanks,
Wcladley
