- Sep 11, 2004
- 144
- 0
- 0
System specs are in my sig.
Config:
-HDD in SATA1 slot on mobo
-DVD-RW (Master) and DVD-Rom (Slave) on secondary IDE slot on mobo
-Vid Card in 1st slot
-Currently in SLI mode (I tried it in single mode too but same thing happens and it came in SLI mode and the manual says it should come in single mode)
-Tell me if you need more info
Problem: I get to the point when my screen says "windows setup" or something like that in the top left corner of my screen and then at the very bottom there's a line that says "setup is loading files (xxxxxx)" (not far at all into the install actually its the first thing of the install). Once it prepares all the files it reboots and does it over and over again. Does anyone know what to do? Thanks in advance.
Config:
