Problems w/win98 and a router
JBChance
150
I've got two computers on a router and I have a problem with one.
I connect thru a cable modem. That's why I have the router. I used to use a hub, but it couldn't work w/ the cable modem.
The one machine uses winXPpro - no problem. The second, has win98. Normally, I get an icon in the taskbar for the internet gateway. But, always when I re-boot, and sometimes just sporadically, the gateway will disappear. Sometimes, I'll still have access to the internet, other times I won't. Even if I still keep access, the computer has serious slowdown and often hangs. When I try to shut down, I often get a hang because the internet gateway application is not responding. I can get the gateway back only by shutting off and powering down everything and powering up normally (modem then router then servers).
Any experience / fixes for this?
Thanks for any help.
JBChance
150
Yeah, it's something like that - probably doesn't say application. Next time it happens, I'll see exactly what it says.
It loses the gateway (icon disappears out of the systray) and then it causes a big slowdown, including not letting me shutdown normally.
Not sure how to fix it
JBChance
150
OK,
I rebooted to make it happen. Booted normally, then the icon for the gateway appeared in the tray and then disappeared. Complete lockup after that - I can move the mouse but can't click on anything. Ctrlaltdel does nothing also.
I had to shut the power down. I'm waiting for it to boot again.
Anyone have any experience with this?
