Problems w/ Abit KT7-RAID and Addtronics 6890A (Case)
zerogear
5,611
9
Everything seems to work flawlessly until this problem. I have the right cable to reset pins, but when I try to reset the computer via the reset button, which works, but after the reset it hangs, the LED lights are on so is the power source, but the monitor remains off and nothing gets initialized (normal computer sounds when resetted). So I checked the cable again, it was on correctly, now I go into the BIOS (CMOS?), and when I change a couple of settings, and exit w/ saving (or exit w/o saving) it does the same EXACT thing. Seems like there isn't enough power or something. What is wrong with my computer. I'm quite sure my computer isn't overheating. Case temp is 20 C, CPU Temp on average is 27-32 C.
Help :(
Edit: by the way, it's a 300 W Power Supply (Addtronics also).
Joelite
23
I dunno how to help you exactally but i have a Supermicro 760 full tower if you wanna buy it email me at synix@lomag.net. I know it works with abitkt7 mobo i have never used this one though.
