Problems setting up Soyo Dragon+ Raid...
mjquilly
I'm having troubles setting up an array on my Dragon+ Board. All I have installed on the board, other than CPU and memory, is my Radeon AIW, HDD's set to Master on IDE 3 and 4, and my DVD and CDRW on IDE2. After POSTing, and getting through the BIOS screens, the RAID setup utility starts and shows "Scanning IDE Drives......." This shows for awhile, then I get this message:
"Warning: FastTrak does not detect proper interrupts, Please check your PCI IRQ setup, and make sure the PCI slot support Bus Master Operations"
What do I need to change?
Try setting your raid HD's to the CS (cable select) jumpers on the back. Then hit ctrl+F when it prompts you to get into the fast build bios. PM me if you still have problems, and I'll check all the settings on mine. Also, make sure you have RAID enabled in the main bios!
I figured this problem out, the problem was that I had my HD's set to "Master", and they needed to be set to "Single". I have another problem now, which I posted here
