Problems setting up new system with Shuttle AK31
AMDAthlonNewbie
When I initally setup the system, it came up at a CPU clock of 100 so it was running at only 200fsb and 1.05GHz. Everything was stable though. When I changed it to 133 to run at its rated full 1.4GHz speed, the system always crash during Windows' boot and won't even go through a boot in Safe Mode. Here is a list of all the settings I can think of.
This is my first Athlon system and I need help from AMD and/or AK31 veterans. Thanks!
Motherboard: Shuttle AK31 v2.0
Memory: 2 Micron 256MB PC2100 non-ECC
CPU: AMD Athlon 1.4GHz 266fsb oem
OS: Windows ME
BIOS settings:
CPU Clokc: 133
DRAM Clock: Host CLK
DRAM Timing: By SPD
Current FSB: 266MHz
Current DRAM: 266MHz
SDRAM Cycle Length: 2.5
Bank Interleave: 2 banks
DRAM Command Rate: 1T
Memory Hole: Disabled
System bios cacheable: Disabled
Video RAM cacheable: Disabled
CPU temperature: 150°F (Using CPU mounted ball bearing fan from Antec)
CPU Voltage: 1.792V
CPU Voltage Default: 1.75V
CPU Vcore: Default
CPU Ratio: Default
DDR Voltage Control: Auto
Auto Detect DIMM/PCI Clock: Enabled
Spread Spectrum: Disabled
CPU temp 150 F !!!!! There's your problem right there...you're on the ragged edge of overheating your processor. You need better cooling or you risk burning up that TBIRD
