Problems setting the correct CPU speed with K7N2 Delta-L
exster
I have a new K7N2 Delta-L with and ATHLON XP 2600+ (333FSB) and Kingston 512MB PC2700 Value RAM.
I have set in the BIOS to 133MHz when I initially installed the OS. At that time, the CPU spec showed as 2000+ instead of 2600+. Now, when I try to increase it to 166MHz, the BIOS loads and when it is about to go into the XP startup screen, it crashes/freezes. I don't see any HD activity when this happens and at that time I know that it has failed.
What do I do?
Thanks (I don't know which forum to post it into so I crossed it to Technical Support also)
