Problems: SATA drive detection + mouse dying
Negatyfus
First, let me give you my specs:
AMD Athon 64 3500+
POV GeForce 6800GT
Maxtor DiamondMax 10 200GB SATA
Asus nForce4 board
Running Windows XP SP1 (still wary of SP2)
Now, I have two occasional problems I'd very much appreciate comments for. The harddisk problem:
- It happens occasionally that I switch on the computer to find that no usuable harddisks could be found to boot an OS from. This is usually immediately solved by rebooting or switching power on and off. Annoying. I have also noticed that sometimes after I shut down Windows (or restarted it) and it shuts down cleanly, I get the "Consistency check required" screen. It never finds a problem. I don't know if this is related. I took a dive with going SATA, but I hope I didn't make a mistake there... SATA being a relatively new technology.
- I have had some problems with my mouse. I've not been able to reproduce this behavior, so I have not tested it much. It has happened a couple of times that my mouse pointer stops moving. All move actions still work, and I can click and move around; it's just that the mouse pointer won't correspondent to the actual "mouse pointer" position. When I reboot, this problem is solved. I'm not sure if this can be hardware related of Windows is just messing with me.
If anybody has any ideas, that would be great. Thanks a lot!
Sorry, did I leave that part out? 😉 It's a pretty good one as far as I'm concerned:
- Tagan TG480-U01 480 Watt
Can't see a problem there, but who knows?
How long has this system been together for? Was it running for a while with no problems and this just started, or have you always had the problem. Have you made sure you don't have any loose connections? Considering the 2 seeming unrelated problems you are having, I would really suspect that the motherboard isn't mounted properly and there may be a standoff out of place, that is shorting the motherboard, or a loose screw underneath.
The system's been alive for maybe a month. It's brand new and I didn't build it myself, but had it professionally done. I hope I can trust that they knew what they were doing, since I payed them money and all.
