I received a MSI Neo Platinum mb w/an FX-55 & 2GB DDR; I very, very carefully installed this board in my case [even wore a grounding strap
!!]; other componets of this setup were a new OCZ 520W PS, ATI X800
Plainum video card, 2 36GB Maxtor U320 SCSI's running off an Adaptec 39320R controller, Sony DRU700 DVD
writer....
Anyway, I assemble this system, boot it up, it boots fine; I look in the BIOS and leave things pretty much "stock"; no overclocking, nothing out of the ordinary. I then install a new copy of Win XP, which goes fine; then
I have to install all the drivers, etc..... for the video card & motherboard [Nvidia chipset, ......]. I get this done, and I'm becoming less and less impressed with this setup. It doesn't seem any faster than my P4 2.4 w/1GB memory
on a P4P800 ! As I install more and more software, I become even less impressed; hangups on shutdown, freezing when using applications, and I've never seen a PC perform so many disc checks on booting back up
as this one did. I'm really depressed now, and read everything I can and search the net; I call tech support
at MSI [that was an expensive and long call !!!]; according to them, I installed XP incorrectly, whatever.....I didn't even bother with Linux after the XP fiasco. Anyway, regardless of what I did, nothing seemed to help.
I even did another clean install of XP from my old CD, with no SP2, same thing. DVD shrink would not work, period, and I do a lot of video editing. ln fact, that seemed to be a big issue, anything correctly recognizing the DVD writer; it was never a problem before, and isn't now (I'm back with my P4 !!!).
I've never had an MSI board, and I've always built PC's using Intel processors; I just never have had great luck with AMD, although I did build up a system for my cousin a couple of weeks ago [a Sempron], and it seemed to work just fine. I really thought the AMD 64-bit processor would really be fast; it wasn't. I know this can't just be me; I had a couple of friends double check the sytem, they could find nothing wrong.
I made a real mistake when I went into the BIOS and set the memory timing to "aggressive"; the thing wouldn't even boot up to XP !!!
Has anyone else had this much trouble with a system? It's been a long, long time since I've spent so much time, energy, and money on a system, and wound up with a crippled system; in fact, I never remember winding up like this !!!!!
Any suggestions or advice would be appreciated; as I stated, I spent a lot of money on this thing, and wind up with nothing.......
writer....
