Nvidiaguy07
A few months back, someone recommended that the best way for me to play games on both my computers in my house was to just map a network drive and use it like that.
For the most part it works great. Had some small problems at first because the cable i was using was limiting my speed to 10mb/s, but besides that and having to enter the steam guard code every time i switch its ok.
My only real problem is some games just will not work at all. I havent tried all my games, but just to give some examples:
ones that work:
borderlands
dirt3
trine
blur
orcs must die
mlb 2k12
team fortress 2
some others
ones that dont:
call of duty black ops
modern warfare 2
portal 2 (weird because it says the (source?) engine wont work)
serious sam 3
warhammer 40k
For all these games (the ones that work and the ones that dont), steam still goes through the install process the first time you try to play it. (.net, directx, all that crap).
Is there something that sticks out about those 5 games that run something that the other ones dont that makes it not work?
Any help is appreciated. also if you have any ideas of how to get around the steam guard crap every time i change computers.
ones that work:
borderlands
dirt3
trine
blur
orcs must die
mlb 2k12
team fortress 2
some others
ones that dont:
modern warfare 2
serious sam 3
warhammer 40k
