- Sep 30, 2004
- 2
- 0
- 0
Have managed to get my new athlon xp-m 2500+ to run at 1.6V at 2.2Ghz (11*200) but everytime i try and go higher than this i have stablity problems. The problems only get worse as i increase the vcore, at anything above 1.7V the cpu will not even post into windows.
Have checked my power supply while under load in windows and everythin seems fine, the voltage lines are with about 2% of what they should be.
Also the CPU runs at 49 degrees under full load in prime95 so i dont believe it is a heat problem
Can anyone help i feel that i should be able to get it to run at higher speeds
Thanks
Jon
Thanks
Jon
