I recently (and finally) put together my new computer (yerterday) and its running great. There are some problems though and would like some help 😛
First off, I have the Asus A8N32-SLI Deluxe Motherboard. It's kickass and is suppose to get great OCing results that I can't seem to do.
System Specs:
Opty 175
Asus A8N32-SLI Deluxe Mobo
2GB OCZ Plat. EB (Inferion Chips) DDR500
2x7800GT's in SLI (with VF-700 on each)
X-fi Sound Card Squeezed between the tow GT's (literally squeezed, had to bend capacitor to make it fit...a lot).
Alright, here is my problem. I can't seem to get to adjust the RAM speed. No matter what I do it seems to be stuck on some crappy ratio (not even a good one) and is running at 140mhz, far less that what it should be.
Second, my mobo won't post if my FSB is over 220. I try lowering HHT, Upping voltage, maby I'm just stupid and doing something wrong. This is my first venture into OCing and I hope it's a good one.
Thanks for help 😛
UPDATE:
After using that "Quick and Dirty" Ocing Guide, I now have my processor at 260x10 (2600mhz) and it's stable at stock voltage. Well, if you consider a couple minutes with prime to be stable, hell, I just wanna game, if it crashes then I know it's not stable. I figure, I'll play now and prime later (like when I sleep).
Pics (and click on pic to make full size, you can't read some text at the resized image):
prime pics
CPU-Z 1
CPU-Z 2
So do all my settings look good?
System Specs:
Opty 175
Thanks for help 😛
UPDATE:
prime pics
CPU-Z 1
CPU-Z 2
