rking12345678
I'm moving my parts over to an Antec 300 case and I've come across a problem.
http://i528.photobucket.com/albums/dd325/rking_1_1/back.jpg
The top of the heatsink backplate doesn't clear the window cut out for it and makes contact with the inside of the case. I have standoffs installed in the correct spots but they don't provide enough clearance. Short of cutting the opening open a bit more, which I lack the tools to do, I'm wondering what to do about this. I've thought about doing this:
http://i528.photobucket.com/albums/dd325/rking_1_1/tape.jpg
Adding electrical tape to the section where it hits. Otherwise I could put some rubber washers between the standoffs and the case to raise the motherboard up enough to clear.
I've never seen a backplate before, it's been a long time since I worked with new PC hardware and these weren't around then...long time. I'm not sure if it's even a problem, I just don't know if those two screws/nuts at the top of the plate need to be kept off of the case's metal or not.
Any advice, or does it not matter if those two screws/nuts are touching the case? Thanks for any help, I'd like to get off my laptop sometime soon...
